407 electric window reset
Got a thread up on peugeotforums, but they seem quite slow to reply, so figured it'd be worth a punt chucking a thread up on here too. Wink
Basically, the drivers side rear window on the barge opens no problem, but when closing it reaches the top (closed position), but then comes back down a few inches, obviously thinking something is obstructing it shutting properly.
I've read there is a reset procedure (ignition on - window fully down - window fully up - continue holding switch for 2 seconds - ignition off), but every time the window reaches the closed position, it automatically lowers again, even if I hold the switch. Any pointers?
It's a long shot, I know, but figured it's worth a punt. Wink
You can reset using Peugeot planet, done it on a 307
Forgot I put this thread up![emoji38]
Sorted it yesterday, turned out the window wasn't lowering fully after all. Whilst trying something else, I put the window all the way down, then pushed the switch again, and it went down a little further. Got it to its ACTUAL lowest point, wound it up, held the button, and jobs a good'un. Wink
