Camshaft carrier
Camshaft carrier
Has anyone had experience with leaking camshaft carrier on hdi. Can seem to find a gasket or is it rtv / silicon sealant thanks
the black plastic cover is a gasket and the cam carrier is a sealant
I would be right in saying its a cambelt off job wouldn't i as ive only just done cambelt
With the price of your oil I wouldn't worry about losing a bit... Tongue
Whats worrying me most is if it ends up on exhaust manifold
Tried replacing the top plastic cover seal first?
Yes replaced that about 6 months ago it only leaking in back corner im 90 percen sure it the cam carrier but a spose it worth a check
Over-tightening can cause those cam cover seals to leak, they only need something daft like 12nm iirc. Another option is the vacuum pump seal, they seem to be a common place for leaks.
  Camshaft Kapi306 0 2,745 08-02-2020, 09:48 AM
Last Post: Kapi306
  Piper Camshaft JTaylor2005 4 4,046 22-05-2018, 03:55 PM
Last Post: Piggy
  camshaft sensor reasey1992 2 3,241 10-03-2013, 07:19 PM
Last Post: Poodle
