07-02-2016, 03:51 PM
Has anyone had experience with leaking camshaft carrier on hdi. Can seem to find a gasket or is it rtv / silicon sealant thanks
Camshaft carrier
07-02-2016, 07:59 PM
the black plastic cover is a gasket and the cam carrier is a sealant
07-02-2016, 08:04 PM
I would be right in saying its a cambelt off job wouldn't i as ive only just done cambelt
07-02-2016, 08:05 PM
With the price of your oil I wouldn't worry about losing a bit...
07-02-2016, 08:09 PM
Whats worrying me most is if it ends up on exhaust manifold
07-02-2016, 08:37 PM
Tried replacing the top plastic cover seal first?
07-02-2016, 11:38 PM
Yes replaced that about 6 months ago it only leaking in back corner im 90 percen sure it the cam carrier but a spose it worth a check
08-02-2016, 06:19 AM
Over-tightening can cause those cam cover seals to leak, they only need something daft like 12nm iirc. Another option is the vacuum pump seal, they seem to be a common place for leaks.
| Camshaft | Kapi306 | 0 | 2,942 |
08-02-2020, 09:48 AM Last Post: Kapi306 |
| Piper Camshaft | JTaylor2005 | 4 | 4,399 |
22-05-2018, 03:55 PM Last Post: Piggy |
| camshaft sensor | reasey1992 | 2 | 3,496 |
10-03-2013, 07:19 PM Last Post: Poodle |
