Bang and grind noise
Hi guys tonight I was driving the van going steady all was fine. Stopped then set off as I went up the hill I hit boost and heard a bang and a grinding noise. Stopped everything looked fine so set off all was well and did it again on boost. Any ideas? Sure release bearing has got louder now as it didn't make a noise before
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Bigger hammer?
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
Nothing wrong with a little bang and grind....
My mind is tellin me noooooo....
But my body....my body's telling me yeah-eh-ess...
Haha. Drove it again just out of gear and grinds. Now at point to when setting off it will jump out of gear. Goes into any gear fine but one I'm letting the clutch out it will grind or will drive for a few seconds
Ph3 perv cab heaven
Black ph1 XUD died
suspect gear box, bang and grind after hitting boost??
jumps out of gear, and grinds when coasting, you sure drive shafts and engine mounts all good??
Release bearing collapsed
Ph3 perv cab heaven
Black ph1 XUD died
  Is LDA pin grind worth it with K03? johnny625 7 6,242 20-01-2021, 04:02 PM
Last Post: Martin306
  berlingo bang xudlingo 1 2,225 12-05-2015, 04:46 PM
Last Post: Jonny81191
Thumbs Up Gov mod/LDA grind on standard turbo philpemberton94 5 4,548 19-03-2014, 09:25 AM
Last Post: mr_fish
