01-02-2016, 05:48 PM
		Well if you are, snap these Brembo Max Discs up quickly, remember these will NOT fit standard 266mm Peugeot 306 Brakes, only calipers from the 307 or if you have a 307 with 266mm front brakes! (I know, bit of a long shot but someone gets a bargain hopefully)
http://www.amazon.co.uk/Brembo-09-8695-7...-0&sr=1-10
Look on the right and select the "USED" discs, while it says it is used, most likely it's just the box that is damaged. I bought a pair of 283mm and the discs were brand new, the box was only slightly damaged in the corner!
P.s, you can check your cars fitment here:
http://www.bremboaftermarket.com/En/Car_...Mode=Model
