HP Fuel Pump FPR Bolts
Does anyone have a broken HP fuel pump and willing to send out the bolts from the FPR? Huh or if not, the size of the bolts so I can grab some replacements? (Both of mine have corroded and the head's are FXXXED!) Ta in advance!
Same request on bolt size please Smile
Think it's M6 currently?
I ended up buying a whole fuel pump for the two bolts haha. I'll get it measure up tomorrow for you!
M6*15mm
M6 * 15mm is correct. Has a T30 Torx head.
whats the pitch please??
No idea how to measure pitch, I think it's standard? I've included a photo if that helps.
Attached Files Thumbnail(s)
Thanks given by: pug306driver
Probably 1.0mm pitch, use the links below to find them
(27-05-2016, 07:49 PM)welshpug Wrote: Probably 1.0mm pitch, use the links below to find them
And yeah it's 1mm
AFAIK not listed, servicebox is not all that.
I looked yesterday, does have the o-ring specs though.
The O-rings are cheap enough to buy....if your dealer will get them in. Some O rings are supplied in packs of 5, some in 4 and some in 3... they were being a bit arsey with me when I went to go buy the O rings.
cool, thanks, fore armed etc., looks as if a 10mm hex head will fit??
You might find you have clearance issues getting a socket over it, being so close to the solenoid body as they are.
Yeah, hex head is a no go. Bolt won't even fit let alone the socket.
In a pinch you could use a 30mm long bolt and a 15mm spacer, but not recommended.
thanks, will go down the allan bolt route
  Increasing fuel pump output? JTaylor2005 7 1,910 06-06-2016, 10:00 PM
Last Post: Ruan
  Removing Hp fuel pump Welshy_Pete 8 1,788 24-05-2016, 01:42 PM
Last Post: toseland
  Fuel/lift pump Deangatt 2 1,296 21-08-2015, 12:38 PM
Last Post: Poodle
