Heater blower issues
Hi all
The morning I was driving with the blowers on and all of a sudden everything stopped.
A the heater blower and the control panel weren't powered I initially thought a fuse was broken. But the fuse (F5) is fine.
Before I do some more digging does anybody have any suggestions?
(28-01-2016, 06:46 PM)Michaelc5086 Wrote: Hi all
You checked the green relay above the fusebox as it's prone for melting which in turn will stop the blower from working.
Top row second one along from left
Cheers for the advice I'll have a look tomorrow.
Does the control panel itself ever go. I am a little wary as the Haynes manual that came with the car had the page folded over on replacing the control panel.
hey once you ve checked relay might be worth checking the motor its self its easy yo get out just connect it to a battery if its not the motor will prob be the heater resistor
Thanks for the help
  Heater blower issues Dturbo john 5 5,821 13-03-2018, 01:53 PM
Last Post: Toms306
  Heater Blower Issues MY95 7 7,659 06-03-2018, 11:22 AM
Last Post: Magenta Sunset
  Heater blower problem Pingaz 7 5,424 04-06-2016, 01:19 PM
Last Post: Pingaz
