Berlingo boost bus
Berlingo boost bus
Hi guys been away for a while ended up going to the darkside. Some will remember a few of my last cars. Got a citroen Berlingo 1.9d witch is a good van just no power hardly and we all love boost so been meaning to do this for a while. Went and picked up a 306 was only meant to get engine but ended up with the full car WIN. so here's what I have at the moment. Engine coming out of 306 on Thursday night
[Image: edd9cfda96763446c7a72b16aafb2c44.jpg]
[Image: 0de6f5c73ce3ca74b925d7c4d2db13b6.jpg]
[Image: 7fe8b8e1eda93556e8c3de4304c9808b.jpg]
[Image: d0d1e6069756190285ac032470ba6153.jpg]
[Image: 8c9ce0ddc01ac7eec40a0a16fa1fe16a.jpg]
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Been a pain messing around with mounts ect but it's in and runs. Just abit more niggly bits and connect pipes ect then done[Image: 2af495bca773f63bbd864cd11e5b5eba.jpg]
[Image: f8ad5d002ccc65e01ff1c0a9209796e8.jpg]
Ph3 perv cab heaven
Black ph1 XUD died
Happy days!
Long time no see pal. This going super chronic boost or just enough to make the daily drive a bit more bearable?
[Image: mcetg0.png]
Eyup how's it going? Safe boost for now not finished yet should be by Saturday. Do have big turbo ect already [emoji106]
Ph3 perv cab heaven
Black ph1 XUD died
https://vimeo.com/153535826
Ph3 perv cab heaven
Black ph1 XUD died
Plan sounds good,can't wait to see it done.
[Image: Cn91r40h.jpg]
Van is done. Had to change box, clutch, flywheel, timing belt and also move rear fork for lower mount. Now done but not 100% just a few niggly bits left. Also fitted the stereo [Image: bdbd0e8956c5d6aa492feb8654938437.jpg]
Ph3 perv cab heaven
Black ph1 XUD died
[Image: e599a2c2c6431ffa9da2f77dea2db77e.jpg]
Need some wheels now
[Image: 9c9aa8e9af6425743d95ff75ff352b3c.jpg]
Ph3 perv cab heaven
Black ph1 XUD died
[Image: 7084270e313f679c8d6a14efa2c790db.jpg]
Custom sticker
Ph3 perv cab heaven
Black ph1 XUD died
Hi looking good the 1.9D is pretty dead how is it having the DT?
Was it fairly straight forward?
As I've possibly gotta stick a XUD in a belingo multi space and Had a couple questions if I may
Which box did you use?
How did the turbo exhaust elbow work out?
Final don't suppose you have a picture of the lower mount?
Now I know everything yes. Was a pain at the first. Used Xud box with all the Xud mounts. I've got a down pipe of a xantia work fine enough room. As for the lower mount the fork needs to be removed and moved over there is a hole already there just have to drill it too make it abit bigger. What shape is the multispace?
Ph3 perv cab heaven
Black ph1 XUD died
ahhh nice one man thats really helpful ill have a look into it.
guess i would call it phase 1 same front end as yours however its gold and gold/green interior :/ absolutely awful
have you or and are you doing a brake and axle upgrade?
Mines the ph2. Not sure on axle upgrade as these axles do well with weight so may leave it
Ph3 perv cab heaven
Black ph1 XUD died
