Threads: 213
Car Model/Spec: HDI
So the buttons on my key have never worked so had to open the car manually every time (which is an issue when the locks freeze!), and im fancying a newer key such as from a 208/308 or something newer and nicer, how would I go about this? Would it be as simple as taking insides out of my car key and swapping them over an voila?
Thanks
Threads: 61
Car Model/Spec: Phase 1 306 xsS
Given 21 thank(s) in 21 post(s)
13-01-2016, 04:17 PM
(This post was last modified: 13-01-2016, 04:20 PM by Redordead89.)
Nope, the micro board is shaped to the key! And if or when you open the key up there's a little black chip wedged in one of the corners of the key case that must be transferred with the key blade and chip board in to a similar key shell! Later 208 or 308 key cases will not line up with the buttons on the board!
Might be a daft suggestion but have you tried swapping the batteries in the key for new ones?
Cr2025 iirc x2 pack of 2 energisers in asda for under a fiver and almost always works after changing them!
Done and done.
Takes some careful modding of the new key.
Threads: 61
I guess piggy has done this before then! I didn't know it was poss!
Nothing like the key "flick" of a new type fob
Threads: 61
(13-01-2016, 04:42 PM)Piggy Wrote: Nothing like the key "flick" of a new type fob
Might be worth doing a guide on it piggy! Sure as fk most of my keys in recent years have been a bit crap!
Threads: 465
114
Car Model/Spec: Vauxhall
Given 97 thank(s) in 92 post(s)
fit an aftermarket locking kit and you can have any type of key you want
im currently running a flip key on my gti6
and im running a peugeot ish std key on my daily
13-01-2016, 04:59 PM
(This post was last modified: 13-01-2016, 05:09 PM by Piggy.)
No WAY I'm taking that key apart to show how fiddly the bugger was
Wait...you don't have working RCL on your HDi? Think that'd be one of the first things I'd fix!!
Locks dont freeze if well oiled too bud
Threads: 87
48
(13-01-2016, 06:12 PM)Piggy Wrote: Locks dont freeze if well oiled too bud
do not oil locks, graphite power or lube is what you need, I speak from working for a locksmith for a couple of years, oil attracts dirt and shit, will clog the mechanism up eventually
Interesting... Good info.
Always oiled mine with 3in1
Not had a problem yet... But thats worrying!
13-01-2016, 07:01 PM
(This post was last modified: 13-01-2016, 07:02 PM by Toms306.)
Don't need to lube locks these days with RCL...
Until the battery dies anyway. On the ph3 diablo I had back in 2010 it had one seized lock and one with half a blade stuck in it... That was fun when the RCL stopped working a week after buying it...
True with 306s... But for instance the 206 petrol cap needs a key... As do some other, dare I say, non frenchies
Threads: 16
Given 3 thank(s) in 3 post(s)
(13-01-2016, 06:23 PM)Mattcheese31 Wrote: (13-01-2016, 06:12 PM)Piggy Wrote: Locks dont freeze if well oiled too bud
Yeah they recommend you rub a pencil on the key and then insert it into barrel.Doing this a few times should lubricate the lock fine
Late 306s have a key as well, as do a lot of earlier 00's stuff... Lot of hassle compared to the EasyFuel on the Focus.
Wow...never knew late 306s had a key fuel cap...never seen one.
The pencil/graphite idea is a good one
Threads: 87
48
(13-01-2016, 07:22 PM)roland rat Wrote: (13-01-2016, 06:23 PM)Mattcheese31 Wrote: (13-01-2016, 06:12 PM)Piggy Wrote: Locks dont freeze if well oiled too bud
100% true fella, as we all know pencils are graphite and not lead like they were errrrrrr a long time ago . . . . . a pencil is what i use if i don't have any powder to hand, don't get me wrong, oil will free a seized lock but it will clog the mech in the end . .
Threads: 61
(13-01-2016, 08:02 PM)Mattcheese31 Wrote: (13-01-2016, 07:22 PM)roland rat Wrote: (13-01-2016, 06:23 PM)Mattcheese31 Wrote: (13-01-2016, 06:12 PM)Piggy Wrote: Locks dont freeze if well oiled too bud
+1 my bro is a locksmith and uses ambersil graphite spray powder! Great stuff for less than the price of 2 new batteries! ;-)
(13-01-2016, 07:49 PM)Piggy Wrote: Wow...never knew late 306s had a key fuel cap...never seen one.
Yep, Y reg onwards I believe, I've only ever had one daily with it. I hated it lol, but couldn't just swap it for a standard one as the filler neck is different.
Threads: 0
Car Model/Spec: na
Country:
(13-01-2016, 08:18 PM)Redordead89 Wrote: (13-01-2016, 08:02 PM)Mattcheese31 Wrote: (13-01-2016, 07:22 PM)roland rat Wrote: (13-01-2016, 06:23 PM)Mattcheese31 Wrote: (13-01-2016, 06:12 PM)Piggy Wrote: Locks dont freeze if well oiled too bud
I agree with you, i also have asked locksmith fulham near me about it and they also suggested me to use ambersil graphite spray powder.
