Headflow formula?
Headflow formula?
Does anyone know a formula for converting headflow into hp
 Obviously it's going to be rough but I'm just interested when people say "this head can mame xx hp based on flow"
[Image: mcetg0.png]
Dont forget the head gasket modifier that you have to include for headflow leakage on the rover engine.. somewhere between 60 and 100%
/Toseland
also the calculation for the fuel magnets and electric turbo you've fitted
GTI6 Info
If you have to ask you'll never know Tongue
Well now im not on my phone at work was able to do some proper googlin
http://ls1tech.com/forums/advanced-engin...k-rpm.html
Here is a 4-year old quote from a great head porter and engine guy, Larry Meaux:
"Peak_HP = Flow_CFM * .257 * Number_of_Cylinders
This is the estimated potential Peak HP to expect.
You multiply 87 percent (.87) times cam's theoretical max lift , round off to nearest .050" in Flow Test, then see what CFM is at 28 inches of H2O.
example=> .700" Lift cam:
.700 Lift times .87 = .609" Lift
Flow head at .600" Lift , then take CFM at 28 inches and calculate HP potential with above formula.
.257 Factor = for beginning engine builders and engines near 10.0:1 Comp Ratio
.285 Factor = would be for Professional engine builders with wet sump pans, lightweight rotating assemblies, low tension great sealing rings, deep oil pans, etc. and excellent use of inertia/wave tuning with 9.5 to 11.5:1 Comp Ratios or 11.5 to 13.0:1 CR ranges without fully utilizing inertia/wave tuning effects
.300 to .310 Factor = Current ProStock Technology with dry sump, unlimited carburetion, High Comp Ratio, ultra lightweight rotating assembly, etc, and maximum use of inertia/wave tuning, etc, 14:1 to 17:1 Comp Ratios.
[Image: mcetg0.png]
flow is but a tiny part of the puzzle, I know of a few engine builders that dont use flow benches at all.
just engine dynos and trial and error, after a bit of maths and what looks right and what worked last time!
  Formula One Chat Ben Jay 24 14,161 07-04-2014, 06:59 AM
Last Post: Pompey306mark
  Fantasy Formula One Ben Jay 3 3,196 12-03-2014, 09:59 PM
Last Post: Ben Jay
  Formula 1 Chat Ben Jay 46 18,936 14-05-2012, 08:15 AM
Last Post: Ben Jay
