21-12-2015, 05:10 PM
Evening all just a quick question - the new 6 is going in for engine rebuild just after Christmas, which cams would give it a bit more punch? SC is what I'm aiming for about March time. Thanks
Which cams?
21-12-2015, 05:13 PM
wow. your car looks very similar to grants old one! Im not clued up about cams but also interested to know. As far as I know ther eis only one set that you can fit with standard pistons otherwise you need to get the piston machined so that it doesnt hit the valve. Issue is that the pistons sit flush with the hear of the block when fully up so there is very little room for extra lift in the standard setup.
What exactly are they rebuilding on the engine? Thanks given by: Xsikid
21-12-2015, 05:31 PM
(21-12-2015, 05:13 PM)Eeyore Wrote: wow. your car looks very similar to grants old one! Im not clued up about cams but also interested to know. As far as I know ther eis only one set that you can fit with standard pistons otherwise you need to get the piston machined so that it doesnt hit the valve. Issue is that the pistons sit flush with the hear of the block when fully up so there is very little room for extra lift in the standard setup. It's done 107000 now so my bro in law is going to put fresh bearings/seals, piston rings etc so when it gets SC it will be as good as new . So is it better for longer duration cams rather than high lift?
21-12-2015, 06:48 PM
you dont want to be changing the cams if your supercharging to much over lap!
90' 205 gti6 supercharged
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/ Thanks given by: Xsikid
21-12-2015, 07:14 PM
21-12-2015, 07:18 PM
Not really know. Now you need to think of power you're after. If its low boost, just build a healthy standard engine (maybe with a lightened fly). If you want any more than probably 270ish bhp, i would look at forged pistons and rods.
1999 China Blue 306 GTi6 - Eaton Supercharged - 214.5bhp 181lbft Thanks given by: Xsikid
21-12-2015, 07:24 PM
(21-12-2015, 07:18 PM)Niall Wrote: Not really know. Now you need to think of power you're after. If its low boost, just build a healthy standard engine (maybe with a lightened fly). If you want any more than probably 270ish bhp, i would look at forged pistons and rods. Am going low boost so just want a decent fresh engine , any preference on which flywheel and also will a new standard clutch be up to the job? :-)
21-12-2015, 07:34 PM
Standard valeo clutch will be up to the job if you look after it yeah.
Flywheel i think nearly all the lightened ones are made by a company called TTV or something similar?
21-12-2015, 07:51 PM
21-12-2015, 08:10 PM
Think Rich Walker sells the TTV flywheels cheaper than anyone else so it might be better to speak to him.
21-12-2015, 08:43 PM
22-12-2015, 12:02 AM
You'll be lucky to hone the block for new rings, these engine's wear bores very quickly
22-12-2015, 06:41 AM
S16 cams | Dan Baines 89 | 4 | 1,576 |
25-03-2016, 10:00 PM Last Post: miles |
Cams!!?? | Beany58 | 46 | 8,670 |
05-02-2016, 03:22 PM Last Post: fatlapit |
Uprated Cams - BHP Gains? | 9Freedman9 | 41 | 8,484 |
10-01-2014, 03:06 PM Last Post: THE_Liam |
