Top tensioner bypass
My top tensioner ( the one attached to the big spring) will not sit in a true position for an unknown reason? I've replaced the thing twice and itmonly lasts a couple moths before it starts throwing the belt off. Can I use a smaller belt and just avoid it using only the bottom tensioner?
Any clues anyone?
Probably not, are you fitting new good branded units?
Is your bottom pulley in good condition?
My bottom pully is in good condition and the parts are fine. Its asif where the tensioner sits is warped and makes it sit on aa very slight angle. Over time it just kills the belt. So anyone know if I can just bypass it and just use the bottom tensioner?
Bump!! Help needed!!
I'd say new tensioners, replace it if it doesn't sit straight
need to find out why your tensioners are sitting on the wonk first and foremost
attempting to bypass and run without is a bodge at best
OK cheers guys
  Power steering broken - how do i bypass? WiNgNuTz 35 19,747 23-02-2014, 07:43 PM
Last Post: Tom
