Big 4 core copper radiator | 205 / 309 / 306
For Sale: Big 4 core copper radiator | 205 / 309 / 306
Pretty sure this is a 205 / 309 radiator by the looks of the connectors
Custom 4 core copper
Came off jammapics 306, so will fit a 306 no probs
Had it with intention of fitting to zx, but would require me re-routing boost pipes because i run between rad and chassis leg, and has been sat since.
Having a clear out
£100 open to offers
Location is London, can bring to xmas meet
Will get dimensions
[Image: IMG_4527_zpsyeoc6lv6.jpg]
Want!! Ill see what i can scrap together.
Which means i need to sell stuff to afford this so clearly dont count on me.
65mm core !!
330mm height
800mm width
Any idea how much it weighs? Looks like it uses a different lower pipe to a standard 306?
(22-11-2015, 09:12 PM)DemonDriverDan Wrote: Any idea how much it weighs? Looks like it uses a different lower pipe to a standard 306?
Sorry for confusion - will physically fit a 306 no problem!
You would have to cut off plastic connector from bottom hose and use a jubilee instead.
Weight wise don't really know, it is deffo heavier than a standard rad though
Ok, no worries then. I hate the bottom connector on the 306 rad but if it's heavier then it's no good for me Smile
(23-11-2015, 07:21 PM)DemonDriverDan Wrote: Ok, no worries then. I hate the bottom connector on the 306 rad but if it's heavier then it's no good for me Smile
given the size of it be hard pushed for it to be any lighter than standard rad
thursday bump, can bring to xmas meet
Yeah if you want a bigger rad with a bigger core, expect more weight!
Tried looking at my setup? Its keeping my boosted derv cool but faitlapit or whatever his name is runs the same rad
If I'm going to swap it'll probably be for a 106 rad or an adapted 205. I need something that's easy and cheap to replace in the event it gets broken. Already lost 1 rad due to a stone making a hole in it and I think my current one has been hit as well!
Where abouts in London are you?
(01-12-2015, 05:10 PM)Pompey306mark Wrote: Where abouts in London are you?
Stratford, E15
[quote='
Stratford bruv, E15
[/quote]
EFA.
Soz dood. I'm aware I am a twat.
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
(01-12-2015, 06:39 PM)Danny Wideboy Wrote: [quote='
Stratford bruv, E15
EFA.
[/quote]
Heh, not far off tbh
What's the condition of the fins on the other side ?
I'm always in london so collection wouldn't be an issue.
Can you do a better price than £100 ?
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
(02-12-2015, 11:57 AM)andyyy Wrote: What's the condition of the fins on the other side ?
similar as pic, don't have any more to hand atm
welcome to make me a reasonable offer
cheers
Might pop over next time i'm in town if that's alright with you? That way at least I can see it for what it is.
I might be in the centre of London on Friday, working for TFI Friday.
I was there on Monday, but have not looked on here in a while Sad
I would be interested as its a easy swap at the moment with the build going on.
back to the top!
sold!
Someone got a bargain... that cost me 3x that to have made all those years ago!!!
Stops an XUD overheating, full stop! Even after 30 mins of track abuse mine would stay perfectly cool with that on.
Makes me wish I still had it...
JP
