Lift up collar
Need a lift up collar system for the rallye. Pretty much all the stuff that's on the gearstick
Anyone got it all spare?
I've an actual black lift up collar here - £8 including delivery.
You'll probably need to buy a whole stick assembly from someone for the bits attached to it.
Bianca Rallye
1989 205 GTi6 on ITBs
BMW Z4 3.0
Thousands of GTi6 parts availabile.
Ahh bugger what does the assembly look like? Not sure what I need. Thought it was just a collar I could stuck back on as I lost mine many moons ago
Definitely need the whole stick. I tried heating mine up to get it off and there was no way it was coming off. Just swap the stick. The actual lift up collar is easily replaceable. Its just not clear what you actually need though!
How hard is it to change the stick over?
Cba with it if it's a ballache. The bike lever can stay for abit haha
Stick assembly is nla from peugeot
P1 XSi track car
2.4 LWB T4
So when you removed the collar to fit whatever you did, what did you do to the plastic bits joined to the stick? Cut/break them off?
If not, and you just slid off the collar then you may just need the collar.
Bianca Rallye
BMW Z4 3.0
take a photo....
I swapped the whole stick. Bolt under car to the links and 4 under the center and it all comes out
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
i don't have anything anymore. It all came off, litterally just a knob and a little bit of plastic that the cable sits into
  Wanted: 6 speed reverse cable + lift up collar zx_volcane 7 4,394 24-11-2013, 03:26 PM
Last Post: HDIkyle
