05-11-2015, 09:29 PM
As above, no matter where I turn the dial, it always spins at max setting, if I turn it down to auto, it slows down ever so slightly.
Any advice?
Any advice?
Heater fan stuck on max setting?
Any advice?
05-11-2015, 09:38 PM
Sounds like the cable has popped off the back? Im not sure if that one is cable driven. Im sure someone else will know.
05-11-2015, 09:52 PM
That one isn't, the dial to change the location of the heat is on a cable, I've got two control panels too, tried them both and still the same thing
I reckon it's the motor at fault. The resistor pack is built into the motor on the ph2/3 iirc. Fairly cheap and easy to replace, as long as youlike laying upside down in footwells.
05-11-2015, 10:19 PM
I don't! I've changed it 3 times now and it only stays in with 2 bolts, because the bolts physically don't grip on two of the holes
05-11-2015, 10:43 PM
Tom there is no resistor pack like the one you are thinking on the manual control 306s.
Try unplugging the temp sensor in the overhead console and see if your issue persists.
07-11-2015, 12:03 AM
This may be me being very stupid but overhead console is the thing with the interior light in, right? It's midnight I'm allowed to be stupid haha.
07-11-2015, 12:44 AM
07-11-2015, 04:24 PM
(05-11-2015, 10:43 PM)Niall Wrote: Tom there is no resistor pack like the one you are thinking on the manual control 306s. I thought the variable resistor thing (maybe poor wording on my part) was in the motor housing with that massive heat sink? And yes, you are correct about the overhead console Lewis. |
Heater on low setting perminant 306 | Welshy_Pete | 11 | 3,160 |
17-02-2012, 07:57 PM Last Post: kingy |
