  • 1 Vote(s) - 2 Average
Direct fit turbo upgrade. (hdi)
I MAY have found something of use to the hdi boys out there. Some 307 2.0 hdis same engine thats in our little 306s dont run a gt15. They run an ihi rhf4 with the manifold they would be a direct fit bar the exhaust flange. Messaged poodle last night and his a little upset the rhf5 flanges arent the same. But hey ho. This has no use to me at all. So havnt bothered looking into compressor maps etc to see how good they are. But the leg works there a hopefully this will be some good news for the hdi boys.
Had a 307 hdi 90 at work month ago for a headgasket job that ran an IHI i hadnt realised before that , that they used them
[Image: av5ym8.jpg]
What would be better about those turbos? If they are off a same horsepower car?
Found these on the net after a quick google as well.
[Image: turbo-chart6.gif]
[Image: turbo-chart8.gif]
[Image: turbo-chart5_big.gif]
Compare the compressor maps. Just a good bit of info for people and if not its a different manifold may open up more options for fitment.
Ahhh I am seeing it now Smile
306 HDI 90
[Image: %24_57.JPG]
307 HDI 90
[Image: %24T2eC16h,!)sE9swmcM0vBRRln!td3!~~60_57.JPG]
That is very interesting
Wonder what boost/figures they can handle and how they drive compared to a GT15/K03!
Look quite a bit larger than a GT15!
Have a look at the chart that jtaylor posted, that'll give you a good idea.
Very similar in performance to the gt15, although should be a bit more reliable when abused.
Thinking about this, could you hybridise this with the IHI RHF5 internals, then it would be near enough straight bolt on and an easy stage 2/3 turbo?
Used on 406s and a few other HDI's ive seen on eBay.
You would most likely hit the same snags as suffered by other hybrid turbos, though the only way to know for sure is trying it to see.
So im thinking about following my own advice and using this turbo
no.. definately buy mine =D its much better haha
/Toseland
Hi all
I've found a direct fit to our HDi's and it's a Garret Gt 1852v from Renault (espace, laguna, velsatis)!! Hope that would be useful Smile
[Image: images?q=tbn:ANd9GcQ2AdxKSoQZku7i1plHJMe...NqxDGKrmzQ]
Check???  Rofl
Cheers
_______________
Luis
Have you tried it yet???
No I didn't bash... That other friend oh mine that i refer in my other thread run's one of this... welded to the manifold! They dont believe in flanges xD
____________
Luis
Id like to see one actually bolted to a maniofold. As it seems a bit to good to be true. The flange looks the same
(13-03-2017, 06:40 AM)bashbarnard Wrote: Id like to see one actually bolted to a maniofold. As it seems a bit to good to be true. The flange looks the same
And you will see one bolted!!  Rofl In the end of this mounth i'll be fitting one of these, and I hope that bolts right away to the manifold! But yes the flange have the same design exactly! Let's see...
As soon as I start the project I'll open a thread with all photos and process! I'm feeling confident  Tongue
_____________
Luis
awesome i look forward to it. If it goes well i may try one myself
The 206 engines sit at 15* - 306s sit at 30* and the car is totally different Luis' will be a LHD with the master cylinder on the other side etc etc... So many differences.
I suspect also the boost hose routing will be a problem due to the compressor housing outlet pointing the wrong way, simply bolting to the exhaust manifold is merely a fraction of the work in getting a turbo to fit!
(13-03-2017, 12:39 PM)Ruan Wrote: Remember that even if it fits Luis' car... That's a 206 - the 206 engines sit at 15* - 306s sit at 30* and the car is totally different, Luis' will be a LHD with the master cylinder on the other side etc etc... So many differences.
Yeah i agree bolting to the mani is half the work. But its half the work already done. I didnt know 206s sat at a diffrent angle. I also didnt know luis' car was a 206
Correction - I'm getting confused!
I thought Luis was someone else who signed up recently with a 206, I'm wrong - reading the "Car Model/Spec" says he has a 306 Wink
Even so, things are a bit different as it's LHD - but I seriously doubt it'll be bolt on either way.
Let's see let's see, but please pray for me and get those figers crossed PLEASEE *.* ahaha
The only thing I know about the angle is that you have to change the position ofthe actuator sothe turbo fit (it hits the firewall I think)
Have a nice day!!
___________
Luís
Hi mates good night to all
Just found this right now, might be helpful!
[Image: %24_57.JPG]______________
Luís
  2.0 HDI RHZ 109 turbo upgrade and MAP bibikola 6 8,928 14-10-2018, 04:39 PM
Last Post: madmadmax
  Turbo upgrade Jukie88 22 14,482 23-09-2012, 04:02 PM
