Spacers on the front wheels
I have a 1.8 Phase 3, and just recently purchased some 307 Arianes to go on, I'd read before hand that i needed spacers on the back so I bought some 15mm hubentric. My problem is the front wheels are very very close to the suspension strut and on the test drive after fitting the wheels I found the inside tyre wall very warm!
I was wondering if I put 15mm spacers on the front too to clear the strut comfortably, but what will it do the handling? that's my only concern!
Cheers guys.
1.9 diesel Phase 2 - scrapped
1.8 meridian Phase 3 - going strong!
iirc you have 6.5" x ET31, so 15mm would be ideal.
(03-11-2015, 02:08 PM)welshpug Wrote: iirc you have 6.5" x ET31, so 15mm would be ideal.
Thanks for the help buddy, much appreciated.
i had 5mm on the front and it was fine. with 15 yeh you definitely want hubcentric and not just a standard spacer.
(03-11-2015, 03:39 PM)Eeyore Wrote: i had 5mm on the front and it was fine. with 15 yeh you definitely want hubcentric and not just a standard spacer.
Mine were very close even with 5mm spacers, i'll be going 15mm hubcentric I think, what do you think it'll do to the handling?
Make it very close to standard offset.
(03-11-2015, 04:21 PM)welshpug Wrote: Make it very close to standard offset.
Not really clued up on this, never put spacers on the front before you see. So it should handle like normal ?
oh sorry im talking about when i did it and i had different wheels. If your wheels are ET30 and standard 306 wheels are et15 then you need 15mm spacers to make up the difference. like this...
[Image: file-67.jpg]
itll handle fine if they are fitted correctly. there are plenty of track cars running spacers as the Team dynamic 1.2s are often difficult to find in pug fitment but easy to find in ford fitment.
That makes more sense to me now, thanks. Diagrams are so much easier to understand haha!
  Adaptor wheels spacers? peugeot > ford fitment? Matt-Rallye 14 7,854 28-02-2014, 01:06 PM
Last Post: Matt-Rallye
  Alloy wheels, spacers, sprigot rings and bolts mspdan 2 2,557 06-01-2014, 01:56 PM
Last Post: mspdan
  Wobble from front wheels Low306 9 5,211 10-10-2012, 08:59 AM
Last Post: 306__xrdt
