NSF HEAVY suspension clonk/knock
#61
https://youtu.be/RfK8f5Q3sd0
Skip to 40 wish seconds - 1 minute and you can hear mine. Is that what yours is like piggy?
Its getting to the point, im going to drop the N/S Suspension off and rebuild it again, bloody frustrating.Angry
1999 2.0 8v Turbo 306
You Tube: 832 Performance
(03-11-2015, 04:31 PM)Niall Wrote: Skip to 40 wish seconds - 1 minute and you can hear mine. Is that what yours is like piggy?
yeah does sound similar.
Often I get at least two heavy "clicks" when pulling away though.
(03-11-2015, 05:05 PM)PUGNUT_XS Wrote: Its getting to the point, im going to drop the N/S Suspension off and rebuild it again, bloody frustrating.Angry
see...
I've done that lol
NS chassis rail is cracked around the gearbox mount captive nuts?
GTI6 Info
(03-11-2015, 08:04 PM)cully Wrote: NS chassis rail is cracked around the gearbox mount captive nuts?
not been able to look at that yet.
I STILL have yet to lift the engine off its mounts to check them all.
This I plan to do friday.
Plan is...hoist engine up. blocks under for safety.
Remove all mounts and inspect.
Got the same noise on mine to, a clunk when pulling off and under heavy braking and sometimes over bumps also sometimes changing up under heavy load. it's been to three garages and they can find anything wrong, i am exhausted with it now, everything has been changed shocks,springs,spring cups,droplinks,ball joints,bottom arms,arbs,arb clamps, all bolts/nuts. :-(
The Peugeot 306 is very much like forrest gumps box of chocolates, You never know what's going to f*ck up next.lmao
Mine turned out to be a FG bonnet lmao
(11-12-2015, 06:53 AM)Piggy Wrote: Mine turned out to be a FG bonnet lmao
Ffs, least you finally tracked it down!
Aye...hence the bonnet raisers to see if it was
They won't be staying...just a test procedure
  GTi6 Knock Toms306 12 3,413 21-04-2018, 09:05 AM
Last Post: Toms306
  Rattly knock!! insomaniac45 4 1,154 22-07-2016, 01:18 PM
Last Post: Dale
  Knock Knock..... nick000 12 3,558 01-05-2014, 11:52 AM
Last Post: nick000
