Threads: 186
6
Car Model/Spec: Peugeot 306 2.0 HDI
Given 17 thank(s) in 17 post(s)
Any of you lot using different oil iin the winter? 5w-30 / 0w-40 or anything like that? Mine is due an oil change soon so could change thickness then if it's worth it.
Jack
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
Can see it really making that much difference tbh
Threads: 386
87
No...
You do like making extra work for yourself, Jack.
Threads: 186
6
It's getting changed soon anyway. It would be no extra work yo use a different grade haha.
I have done 12k in this car now and it had an oil change about 3k into it so it's over due tbf.
Threads: 386
87
But presumably you'd then change it for thicker oil again next summer...
Threads: 186
6
Well looking into the ratings s 0w-40 is thin in cold weather's and then still normal 40w once up to temperature.
Threads: 386
87
So the question should be 'should I use thinner oil all year round'.. Answer is probably not as there's more chance of leakage. What benefit were you hoping for from thinner oil? More power? More mpg? I very much doubt you'll notice anything at all on an old HDi, they really aren't fussy like some modern engines.
Threads: 186
6
Nahh it isn't thinner over all. Urm
Reading about it now. The 0w means it's thinner than 5w at 0 degrees C.
Which is good for cold start ups as it's flows better in the cold and also doesn't cause as much struggle turning the engine over due to the oil being like syrup.
The 40 rating (without the w) is the thickness once at 100
Using 5w or 0w - 40 only makes a difference when the engine is colder. The 0w being thinner when it's cold so it flows better. Then once up to temp they behave the same
Just read that some where. Learn something technical every day haha
Threads: 386
87
Yeah that's right, so it'll be leaking on your driveway at cold start but make no difference when up to temp..
Honestly, 10/40 really isn't that thick in the cold though, I wouldn't bother but the decisions yours of course.
Threads: 117
119
Threads: 30
5
Car Model/Spec: 306 HDi Dturbo 5dr
Country:
Yeah, not much point changing... unless you live in an very cold region, if you do, pm a couple of our Swedish or Norwegian comrades and ask their advice/experience
Hdi's are pretty hardy engines, as long as there's a regular oil change
Threads: 202
58
Given 29 thank(s) in 28 post(s)
Yeah, use the same oil year round, change it regularly and don't rag it from cold and it'll be fine.
Threads: 386
87
It's a HDi ffs... You can chuck any old shite in and redline them off your driveway every day, still cant break them! It's everything bolted to them that breaks.
Threads: 4
6
Given 7 thank(s) in 7 post(s)
If you use oil that's too thin it can drain out of the hydraulic lifters over night and then you get a rough start up. The different oils are for people in extreme climates.
Threads: 266
18
Car Model/Spec: 205 DTurbo
I'll be running 5w40 in my Nissan, but it does get 2-4 oil changes a year anyway so it's no biggy.
Threads: 202
58
(20-10-2015, 07:37 AM)Toms306 Wrote: It's a HDi ffs... You can chuck any old shite in and redline them off your driveway every day, still cant break them! It's everything bolted to them that breaks.
And you wonder why you find them unreliable
Threads: 128
21
Car Model/Spec: Stage3 HDi RHF5@25psi 174bhp
Given 41 thank(s) in 38 post(s)
I tried to redline away from jonny's house and got my keys confiscated.. something about neighbours...
/Toseland
Threads: 386
87
23-10-2015, 04:37 PM
(This post was last modified: 23-10-2015, 04:38 PM by Toms306.)
Threads: 102
18
Car Model/Spec: Ph.1 Gti-6 63k
Given 22 thank(s) in 22 post(s)
Just use recommended oil. Trust PSA more than people on a free online forum.
62k Diablo Phase 1 Gti-6: Project Thread
Threads: 202
58
