Power steering pump whining
Just had to change the spring tensioner on my aux belt so had to move the power steering pump out the way. I didn't disconnect any of the hoses, just pulled it forward for better access. But now it's all back together it's whining when turning! Any ideas?
Belt too tight?
P1 XSi track car
2.4 LWB T4
All the bolts back in on the pump?
Got enough fluid in it ?
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
All bolts back on pump im pretty sure. There's two 6mm Allen bolts and a 13 mm bolt on the top. And would the belt being too tight cause it to whine?
(06-10-2015, 07:07 AM)andyyy Wrote: Got enough fluid in it ?
my bet
Got it sorted. The fluid level had dropped! Cheers guys
If the fluid level has dropped its worth checking of you have a leak.
  How to remove pulley from steering pump leswoollam 1 967 26-06-2021, 10:52 AM
Last Post: Mighty306
  How to remove pulley from steering pump leswoollam 0 728 25-06-2021, 02:51 PM
Last Post: leswoollam
  Squeezing more power out of an already maxed out 11mm bosch pump Paul_13 28 7,133 07-05-2017, 08:02 PM
Last Post: Paul_13
