Threads: 162
21
Car Model/Spec: 306 HDI Dturbo, Estate & GTI6
Given 23 thank(s) in 23 post(s)
Hi,
The alternator on the 307 HDI has a two pin plug on the top where the one on the 306 HDI has a single screw connection that goes to the battery light.
Does anyone know what the second pin does on the 307 alternator?
Threads: 145
5
Given 18 thank(s) in 17 post(s)
sorry cant help with that one but see wiring diagram which may help....they are on here ??
Threads: 162
21
I've tried looking for a wiring diagram online but haven't found anything yet.
Threads: 101
2
Car Model/Spec: 306HDi 90 LX
is one pim big n the other little?
It goes, it stops (as reqd).
Hate Housework!
Threads: 162
21
I think they're both small.
Threads: 162
21
Found out last night what the pins are, one should have an L on it and it goes to the battery light. The second goes to the ECU.
Now anyone know what the wire to the ECU does?
Threads: 101
2
according to my Haynes, 1 wire goes to the instrument panel, the other to the battery +ve via the starter motor terminal
Hate Housework!
Threads: 162
21
The only reason I've been asking about the 307 unit is because I was thinking of fitting one to my 306. The only reason being the 307 one has the overrun pulley.
A smart charge system would be nice if it was a separate module that could be installed but it seems it's built in to the ECU. I guess the system would need to know things like engine load for it to work better not just battery state.
I think I might look into using the 307 unit and put the 306 regulator on it if it fits or look at getting the overrun pulley on the 306 unit.
Threads: 91
83
Was thinking about this today.
Try a late 206 HDi alternator, they seem to have an clutched pulley also, as do C8/807s with the 2.0 16v and 2.2 16v engines, although whether the mounting bracket is the same I'm not sure.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
