No heat, brown plug behind head unit?
Hi everyone, i have the 'no heat' issue with my 306 and upon investigating it seems there is a brown clip directly behind the head unit with nothing attached to it. My question is what connects to this?!! Many thanks.
if that's just a 2 pin its for the alarm led.
If you have no heat it's more than likely incorrectly bled coolant or blocked matrix, that brown plug is for an alarm light on some models Smile
(29-09-2015, 01:41 PM)welshpug Wrote: if that's just a 2 pin its for the alarm led.
I always wondered what that was for!! None of the HDi's I've broken had alarms afaik, never found anything plugged in there anyway.
Ahh fair enough, hoping for an easy fix. Ahh well dash has to come off [emoji29] [emoji37] thanks guys!
(29-09-2015, 01:41 PM)Mattcheese31 Wrote: If you have no heat it's more than likely incorrectly bled coolant or blocked matrix, that brown plug is for an alarm light on some models Smile
As Matt said bleed the coolant or get a garage to bleed it for you if you can't before committing to dash out and check everything else before going that far!
Good luck man hope you get an easy fix!
Just check flaps are working too ThumbsUp
Has it always been like it?
  Hdi / Dreaded brown relay behind the Ecu Jukie88 11 6,033 01-07-2013, 07:51 AM
  Head unit and stalk questions Ben Jay 6 4,501 19-07-2012, 09:44 AM
Last Post: Ben Jay
  audio stalk and new head unit aaron_one 6 4,082 09-05-2012, 09:23 AM
Last Post: aaron_one
