Threads: 190
Car Model/Spec: HDI
So im looking at a 2005 307 hdi as a daily, the 136bhp 2.0 hdi 6 speed.
Any information on this engine non 307 specific?
Reliability? Tunability?
Any insight be helpful
Threads: 213
Car Model/Spec: HDI
Also interested in this as also looking at these. Very cheap for what you get with these at the moment.
Threads: 202
58
They're solid engines, reliable if maintained and very economical if you're careful with the loud pedal. I'd avoid DPF and particle filters if possible. You'll see stage 2 8v power (160-170) with a remap.
Threads: 190
Car Model/Spec: HDI
Thanks for the info, how does the dmf handle that kind of power?
Threads: 202
58
Erm.. Just fine if you understand how to avoid giving it a hard time. Drive it like my housemate drives his mapped S40 and it'll last about 6 months!
Threads: 190
Car Model/Spec: HDI
haha okay I see. Might be worth a look then
Tuning potential should be greater if you're looking at going mad with it, much easier to find suitable injectors.
Threads: 190
Car Model/Spec: HDI
thanks for the info ruan, but I am actually looking to buy the car as is and not retrofit it to a 306.
Would the 1.6 16v hdi be a better shout in the 307?
Threads: 190
Car Model/Spec: HDI
Going to look at a 307 RHR as having looked at e46 320d they seem to have way more faults
Probably better off with the 2.0 imo, the 307 is a bit of a fat knacker.
Threads: 190
Car Model/Spec: HDI
yeah poodle im hoping the 136 with a remap would be lively enough as I know the 8v 307 is slow as my dad has one lol
Threads: 4
6
Given 7 thank(s) in 7 post(s)
RHR doesn't seem to be too bad an engine. As per normal the turbo is really hard to get to, but I like the fact the fuel pump is on the right of the camshaft so it's really easy to change (if you need to) rather than having to take the cambelt off.
Tuning is really complicated, but it's a really clever ECU so once you find out how to edit things properly it seems to work really well. I got mine up to 170 BHP with just a DPF delete and a hollow DPF canister but I think the turbo was a bit of a duff one, would love to buy another if I had the time but I've got other projects to play with. I think a low mileage RHR would see above 170 quite easily.
