16-09-2015, 08:19 AM
I've seen a few people go from a gti6 box to the 1.8 16v box. To convert it back to 6 speed is it a case of just putting the 6 box back on or do you have to do more than that?
Gearbox Question
16-09-2015, 08:27 AM
your better off going to the xsara vts 5 speed box, as far as im aware its the case of changing the clutch to a xsara push clutch and possibly the cable too.
90' 205 gti6 supercharged
05' Evo 9 IX GT Team eaton. Axle rebuilds please contact me for your needs. https://www.facebook.com/axlesbystef/
16-09-2015, 08:32 AM
(16-09-2015, 08:27 AM)Stef205 Wrote: your better off going to the xsara vts 5 speed box, as far as im aware its the case of changing the clutch to a xsara push clutch and possibly the cable too. The car already has a 5 speed on it but if I was to put the 6 speed gearbox back on would it be a case of just changing the box? Or would the clutch have to be changed as well
16-09-2015, 08:56 AM
youd have to change the clutch.
on a separate note why would you want to stick that box back in its a awful box!
16-09-2015, 09:31 AM
1.8 uses a 200mm push clutch.
gti6 and xsara vts use 215mm pull clutches. you'd need to swap the clutch arm and bracket, cable, flywheel and clutch.
16-09-2015, 10:04 AM
So may as well keep it a 5 speed then?
16-09-2015, 10:14 AM
Sure it's a 1.8 'box? Not a 2.0 XSi one? Not sure which clutch the XSi's use.
16-09-2015, 11:18 AM
16-09-2015, 11:38 AM
Probably has all the gti6 clutch arms fitted then.
if you're getting rid of the 1.8 box I may be interested, if you can post the code off it.
16-09-2015, 01:11 PM
16-09-2015, 04:26 PM
You need to fit the reverse cable as well.
16-09-2015, 05:58 PM
6 gearbox question | mackat | 18 | 5,793 |
26-05-2015, 03:55 PM Last Post: mackat |
