Threads: 11
Car Model/Spec: 1.9 td
Country:
My car is going under the knife today to get a Bosch replacement pump. I understand the pump timing needs to be altered once fitted. Is there a specialist tool needed to do this or is there just a simple way of doing it? Cheers
Threads: 29
Car Model/Spec: 205 1.9 TD
Make sure you get a Bosch Pump bracket as-well or move the studs in the Lucas one or the timing will be way off.
Only tool you'll need to adjust the Pump timing is a 13mm spanner - as said above loosen it off and push the pump forward or back
Threads: 374
38
Car Model/Spec: GTI 6
NOTE: The 13mm bolt UNDER the pump ; is the absolute LAST bolt to tighten up. Once it's done, it's done, you'll never want to touch it again
Threads: 371
29
Car Model/Spec: ford fiesta
Just remove aux belt. Loosen bottom bolt on alternator remove top bolt and lean it forward. Easy to get to then.
Threads: 11
Country:
Ok so we've encountered first problem. How do we wire the bosch pump so its not effected by the Lucas immobiliser? The Lucas has two sets of plugs and the bosch only seems to have one?cheers
Threads: 19
Just find the 12v ignition live using a multimeter.
Normally its the Red wire I've found.
Threads: 11
Country:
What happens to the rest of the wires that where in the Lucas are they needed?
Threads: 11
Country:
Should the pump be quite stiff to turn over by hand?
Threads: 11
Country:
Ah good it seems like mine has freed up then. All I need now is a mechanic who isn't a spas to fit it for me! Mine didn't have a clue!!
Threads: 11
Country:
I'm in west Wales. I'm prepared to travel though to have it done properly!
Threads: 371
29
Id happily do it but im ipswich way. Im sure there are a few members that way that can help you.
Threads: 38
Car Model/Spec: D'turbo S
Where abouts in west wales are you I might no a few people
Threads: 11
Country:
I live near cardigan but as I said I don't mind driving a bit to have it done by someone who knows what there doing!
Threads: 34
8
Given 7 thank(s) in 7 post(s)
If you fancy coming to south east wales ill do it.. Down to newport/cwmbran
Threads: 11
Country:
27-08-2015, 09:27 PM
(This post was last modified: 27-08-2015, 09:28 PM by simonson1982.)
What are the odds? Yeh definitely. I'm down narberth all the time. I could come down to you whenever you want after this week end just let me know!
I'm litteraly gobsmacked was thinking there was no way there would be anyone near me that could do it!
