Threads: 371
29
Car Model/Spec: ford fiesta
And this is why you buy a non thermostat controlled one and keep different sized pieces of cardboard in the car... .....
Seriously though. Good work. As always.
Given 81 thank(s) in 77 post(s)
Was your oil temp gauge not working Cully?
Threads: 371
29
(21-08-2015, 11:54 AM)RetroPug Wrote: (21-08-2015, 10:51 AM)bashbarnard Wrote: And this is why you buy a non thermostat controlled one and keep different sized pieces of cardboard in the car... .....
Or use an oil temperature gauge to see whether or not your car ever gets up to temperature?
Yeah i was kidding obviously. What oil temp is safe to hit though. Mine averages 90 degrees day to day. Barely ever moves off its mark even after a blast.
Threads: 465
114
Car Model/Spec: Vauxhall
Given 97 thank(s) in 92 post(s)
oil rating on the tins are viscosity ratings for temps off 0c/100c
so taking a semi synth oil 30c out of its range it will degrade rapidly
Threads: 371
29
Ok ill bare that in mind and get a cooler fitted at some point.
