Mocal thermostatic sandwich plate
has anyone had experience of these sticking open and not passing to the cooler
i think this has been one of the contributing factors in killing my engine [Image: sad.gif]
just stripped the plate down to clean it and the shuttle part was stuck in the bypass tube
thus only letting oil bypass the cooler not flowing to cooler
GTI6 Info
I have been experimenting in the kitchen!
boiling and cooling the mocal plate
[Image: 20150820_192100.jpg]
i was right! the shuttle is sticking in the plate and not closing
after taking it apart you could see high points and marks where the shuttle was sticking
[Image: 20150820_202027.jpg]
[Image: 20150820_202046.jpg]
[Image: 20150820_202052.jpg]
[Image: 20150820_202106.jpg]
i have now cleaned up the rough castings around the port hole and have also slightly shrunk the diameter on the shuttle
it is now moving more free to the full stroke
GTI6 Info
And this is why you buy a non thermostat controlled one and keep different sized pieces of cardboard in the car... .....
Seriously though. Good work. As always.
(21-08-2015, 10:51 AM)bashbarnard Wrote: And this is why you buy a non thermostat controlled one and keep different sized pieces of cardboard in the car... .....
Or use an oil temperature gauge to see whether or not your car ever gets up to temperature?
62k Diablo Phase 1 Gti-6:
Project Thread
Was your oil temp gauge not working Cully?
(21-08-2015, 11:54 AM)Niall Wrote: Was your oil temp gauge not working Cully?
yes oil temp gauge works and showed 130 at its hottest that day water temp was normal though
like i said poor choice of oil + faulty oil cooler and me being greedy and jumping at Dum-Dums offer of free track time killed my engine
new engine is getting a oil pressure gauge and an early warning 20psi oil light too
GTI6 Info
Yeah i was kidding obviously. What oil temp is safe to hit though. Mine averages 90 degrees day to day. Barely ever moves off its mark even after a blast.
oil rating on the tins are viscosity ratings for temps off 0c/100c
so taking a semi synth oil 30c out of its range it will degrade rapidly
GTI6 Info
Ok ill bare that in mind and get a cooler fitted at some point.
  Mocal Thermostat Pingaz 1 9,955 22-06-2022, 09:05 PM
Last Post: Stef205
  Mocal protection impotentials 19 13,083 10-09-2014, 09:39 PM
Last Post: impotentials
