Weird Issue with relays.
Hey guys,
Noticed today, my indicator relay sometimes ticks madly.....
no lights flash when it does it, and it behaves normally when i operate the indicators, but i noticed that the relay was very very hot.
Has any one got a clue what might be up? or do i replace said relay, and hope it goes away?
any help apprechiated Smile
tony.
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
Its the indicator stalk. Known fault. Get it done asap. Can catch fire if not.
I just had problem with mine where left or right indicator dodnt work but hazard lights worked.
I changed relay, indicator stalk but at the end it was hazard light switch faulth!
ok thanks for the replies. Will source a new stalk asap. Smile
if that does not clear it up, i will replace the hazard light switch.
Thank you
Kindest regards
Tony.
Not always Grumpy!!
(11-08-2015, 11:37 AM)vandalzd Wrote: I just had problem with mine where left or right indicator dodnt work but hazard lights worked.
I had similar and it was the relay. Free from the breakers to replace so worth doing anyway Smile
  Green relays pug306driver 2 4,696 23-10-2022, 01:00 PM
Last Post: pug306driver
Photo Relays and what does what allen54 0 2,513 28-12-2016, 06:44 PM
Last Post: allen54
