fuel pump wire
Hi my gti had broke wire that switches on the fuel pump
Engine loom changed
Relay changed
Earth checked
Has to be car loom running front car has this happen to any one before everything else work fine
Anyone know what wire on the engine plug goes to fuel pump so I can patch it up for time being
Aaaaaa
double plug above passengers feet one of the pins will be burned Wink
GTI6 Info
I will have a look don't think be that 12v isn't even being made at engine loom from relay. Think might be a immobiliser wire code box not talking to ecu dose immobiliser kill spark,pump or both can't remember
on 306 only thing kills the pump is ign, fuse fist stage of double relay or inercia switch
GTI6 Info
Sorted turned out some how the red plug under pass foot got loose so glad wasn't a let's find the broke wire game lol
  Problem with fuel pump nikola_bb 1 2,931 30-07-2017, 12:47 PM
Last Post: zomypammo
  Fuel pump query Orta 3 2,836 27-09-2015, 09:19 PM
Last Post: ozonehostile
  fuel pump not running Brashwoody 5 3,050 25-05-2014, 10:58 PM
Last Post: welshpug
