Standard again after injector change
Wondering if any one could shed some light on my situation. Had car mapped about a month ago all has been good car pulled well through all gears but i had very rattly injectors so ive changed them yesterday for a set that dont rattly half as much but car feels standard again now anyone had experience with this befor.
Most Injectors are coded if you replace them I would assume that they may reset to factory settings.
But if they were coded then it wouldnt run would it? cant see how injectors would make a differance myself.
306 Injectors are not coded to the ecu. You can swap them about as long as all 4 have the same numbers in the code. So a set of four for another set of four say. It would t mess with the ecu map at all. You will ha e another fault somewhere.
New injectors are probably knackered, stick with the noisy ones, I had a similar issue.
Think ill try old injectors again and see whats what with them then cheers any one no where i can get a map file sent ?
No need to configure the injectors on these, there isn't an option on most models.
You definitely can't lose a remap by changing any parts on the car. If you want a remap just drop me an email.
HDI Tuning Ltd
www.hdi-tuning.co.uk
  hdi injector change hdimad 3 2,796 04-02-2015, 08:53 PM
Last Post: DeeTurbo
  injector change help kris_taylor1988 2 2,288 01-10-2013, 10:49 PM
Last Post: kris_taylor1988
