09-07-2015, 07:51 PM
Is the above true?
Runnning with maf unplugged = less mpg?
Is the above true?
09-07-2015, 09:03 PM
depends if said MAF was fooked causing excessive fuel delivery or not, compared to a good maf, certainly.
MAF was only fooked in that if you went to put your foot down there was a large pause before acceleration in 2nd and 3rd and when engine warm it wouldnt accelerate in 4th from 40 at all
09-07-2015, 09:27 PM
Probably fooked then, so i imagine it won't change your mpg much.
09-07-2015, 09:53 PM
Thanks Poodle! Just wanted to make sure before I do the 600 mile round trip to Pugfest on Sunday with it unplugged, then hill runs too
09-07-2015, 10:39 PM
Won't have a massive effect, but I would never expect it to be as good as a fully functioning MAF.
09-07-2015, 11:22 PM
I'm running my 307 sw 110 hdi like this due to anti poll/ dpf issue and according to the computer I'm still averaging 40.9 and I've been doing Dominos in it for 2 months unplugged! Sluggish acceleration slowly creeping back after 2-3000 miles so probably doingore damage in long run but ain't got cash to fix it now so has to wait!
I wouldn't worry about the trip but she may feel a wee bit tired after the hill climbs so just make sure you got proper recovery before you go!
10-07-2015, 12:03 AM
On 110hdi tou can change maf to map based smoke maps on ecu. And then you don't need maf sensor and car response is better on map
10-07-2015, 01:17 AM
10-07-2015, 02:05 AM
10-07-2015, 11:49 AM
306 3 door they handle excellent and can fling them round corners like a buggy! :-)))))
10-07-2015, 04:39 PM
Yes, you will always get worse MPG with the MAF unplugged, it makes small timing corrections based on inlet temperature and intake air mass.
The 110 can run without a MAF as there is a MAP sensor so it can calculate the reading, but will actually be less responsive when compared to a fully working MAF, unless the mapping is tweaked to make it more responsive..
10-07-2015, 04:55 PM
Thanks for the info Steve
How much worse are we talking about on the HDI90? |
| Maf unplugged | nath86 | 16 | 8,815 |
19-02-2014, 10:08 PM Last Post: pro_steve |
| Found this unplugged? | MIKE-FORD | 5 | 4,060 |
01-02-2013, 07:45 AM Last Post: Jole |
