306 TUD5 Turbo Project. - Yes, TUD5 in a 306!!!
#91
(11-08-2015, 03:57 PM)Piggy Wrote: So close bud. Dont give up!
Need any exhaust bits??
I'm good for exhaust bits between what I have lying about and the 2 standard down pipes there is enough bends to knock something up. Just a major case of CBA as I f*cking hate wiring.
(11-08-2015, 04:17 PM)Poodle Wrote: Didn't think you'd done anything to the wiring, just plugged it in and hoped it worked..? No real surprise that it hasn't, they're completely different cars, you give in too easy. Tongue
Have you got all the wiring diagrams for both?
They plugged together so I assumed they'd work, TBH it's not surprising that it doesn't work. Just sick of being underneath cars especially with being injured and bikes playing up. Jonny the midget has an amazing suggestion about using an ph3 1.9D loom which I think I'm gonna go with as that should make the wiring work and have roughly the right sort of plugs in roughly the right sort of places and will connect to the 306 car loom.
(11-08-2015, 07:08 PM)Dum-Dum Wrote: Just a major case of CBA as I f*cking hate wiring.
You mean you can't do it with a hammer, a welder and some cable ties so lose interest?
keep going man. ig you need any exhaust bits i can always send some old stuff from work to you at cost.
Never a truer word said in jest.
That is EXACTLY the reason
(11-08-2015, 07:49 PM)bashbarnard Wrote: keep going man. ig you need any exhaust bits i can always send some old stuff from work to you at cost.
Cheers for the offer mate, Not much to do really, just a down pipe and there's plenty of space to work (compared to an XU lump). I've got 3 different but close sizes of pipe so can sleeve bits and weld them and just cut angles to make bends or cut bends out of old exhausts.
You guys really are helping with my enthusiasm for cracking on with it, top lads Big Grin
Any Ph2 onwards XUD/DW8 loom should work absolutely fine.
Although no need to fart about using the DW8 loom as that has all the advance ECU bullshit in it - a Ph2 XUD loom would be your best bet IMHO.
Only thing that MIGHT need changing from memory is to use a solenoid feed from the glowplug relay, but it's not difficult - all the starter pins, speed sense pins, oil pressure etc pins all work fine, from memory you'd need to just swap a temperature sensor out for the Bitron unit which is diff on Ph3, but then it should work. I basically did precisely this conversion with mine (just that I actually used an XUD, but same theory applies) just plugged in my old Ph2 loom and other than rev counter on the Ph3 clocks, from memory it just worked.
So selling as I now have a motorbike.
£200
http://306oc.co.uk/forum/showthread.php?...#pid552877
You say that, i have genuinely seen wiring jointed with cable ties. have a pic somewhere lol
class project i never thought of putting a tu5d into a 306 tis a mighty idea tho
  DeeC’s 306 VNT Turbo Build / Show Car Project darrencurry0808 63 23,072 30-12-2020, 01:45 PM
Last Post: darrencurry0808
  Project Truck Turbo MkII, gathering dust ozonehostile 418 188,008 29-08-2019, 09:51 PM
Last Post: Dturboleeds
  306 XND to D-turbo track car project Sfin01 0 1,754 01-01-2019, 02:10 AM
Last Post: Sfin01
