The following warnings occurred:
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/class_error.php 157 errorHandler->error
/global.php(961) : eval()'d code 31 errorHandler->error_callback
/global.php 961 eval
/showthread.php 28 require_once
Warning [2] Undefined array key "thxdsp_outline" - Line: 1 - File: inc/plugins/thx.php(309) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/plugins/thx.php(309) : eval()'d code 1 errorHandler->error_callback
/inc/plugins/thx.php 309 eval
/inc/class_plugins.php 142 thx
/inc/functions_post.php 917 pluginSystem->run_hooks
/showthread.php 1122 build_postbit
Warning [2] Undefined array key "thanks" - Line: 40 - File: inc/functions_post.php(966) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/inc/functions_post.php(966) : eval()'d code 40 errorHandler->error_callback
/inc/functions_post.php 966 eval
Warning [2] Undefined property: MyLanguage::$thread_modes - Line: 48 - File: showthread.php(1651) : eval()'d code PHP 8.3.32 (Linux)
File Line Function
/showthread.php(1651) : eval()'d code 48 errorHandler->error_callback
/showthread.php 1651 eval
engine wiring looms differences
question for the peeps in the know
ph2 and ph3 engine looms what are the differences?
ive found the Map sensor plugs to be differant and so is the power steering pressure sensor plug are there any more?
will a ph 3 loom plug into a ph2 car and work if you fit the correct plugged sensors or ph3 engine?
Ph2 MAP
[Image: 20150628_151757.jpg]
Ph3 MAP
[Image: 20150628_151918.jpg]
Ph2 PAS sensor
[Image: 20150628_154054.jpg]
Ph3 PAS sensor
[Image: 20150628_151934.jpg]
GTI6 Info
  Differences between xsara vts & gti6 engines? Matt-Rallye 11 10,243 01-03-2017, 08:50 PM
Last Post: welshpug
  Differences? underground375 1 2,008 16-12-2013, 11:04 PM
Last Post: miles
