zx front drivers side drive shaft
Wanted: zx front drivers side drive shaft
As above need a drive shaft for my zx Driver's side. Unsure if a 306 one will fit?
Needs to be posted if not local to chesterfield
Cheap as possible as usual
AFAIK you need a non pas 306 one, PAS are longer, best bet if its an outer joint is to just swap the joint.
http://www.jandrcvjoints.co.uk try this place, pretty cheap and deliver Wink
(24-06-2015, 05:59 AM)highwayman306 Wrote: http://www.jandrcvjoints.co.uk try this place, pretty cheap and deliver Wink
Is this the one I need? bit hard to tell with out pics lol
http://www.jandrcvjoints.co.uk/citroen-z...ide-91-98/
If you give them a bell they should be able to put you right but I would say if your year and model falls within that description, its the one Wink but try belling them all the same, just to be on the safe side Wink
if its a non pas 306 one you need then i have one of those here that you can have for cheaps
I'm sorted now bought a new one thanks for offer tho
Did you get it from J and R? I'm interested to hear what they charged you for postage... Wink
(26-06-2015, 05:59 AM)highwayman306 Wrote: Did you get it from J and R? I'm interested to hear what they charged you for postage... Wink
No I didn't got it from car parts 4 less
j+r were free postage when I used em a couple of weeks ago.
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
I thought they were supposed to be cheaper for delivery, cost and good speed of delivery?
Oh well Smile
  Wanted: 2x Drivers side doors MOSB Dark Green Met Paul Baldwin 4 4,220 04-02-2018, 09:06 PM
Last Post: Paul Baldwin
  306 hub drivers side Teddy 3 3,161 01-02-2017, 05:40 PM
Last Post: Bradwatkins740
  Wanted: Phase 2/3 Drivers front wing anto 4 3,881 17-05-2016, 11:14 AM
Last Post: anto
