Threads: 465
114
Car Model/Spec: Vauxhall
Given 97 thank(s) in 92 post(s)
both types
[attachment=23960]
Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
22-06-2015, 06:26 PM
(This post was last modified: 22-06-2015, 06:27 PM by bigcheez2k3.)
Thanks. Hopefully mine is the left one, now just need to find somewhere with one.
EDIT: Are XUD and HDI ones different? Because my current pipe is in 2 different pieces, so I don't know it's a half of one and half of the other.
Threads: 41
28
Given 86 thank(s) in 85 post(s)
I've never had a HDI bottom hose off, but as far as I can tell on SB they use a normal push on hose, where the XUD can use either of the push IN and o-ring hoses, earlier ones used the black plastic bti later ones the metal with the wire clip.
Threads: 34
8
Given 7 thank(s) in 7 post(s)
My ph2 had the metal type, and ph1 had plastic type
Threads: 143
10
New pipe doesn't fit :/
Have a feeling it may be a HDi rad which would explain why the current pipe is 2 pieces joined together.
Threads: 0
45
Yup it's a HDI rad IIRC as the DT donor one had an extra outlet we didn't have anything to blank it with. Hence having to join the HDI & DT.
Threads: 41
28
heat exchanger one? also probably the bleed pipe from the thermostat housing
so just to confirm...
which rad are you using??
Threads: 0
45
We fitted an XUD into a HDI shell, using the HDI rad due to the XUD rad having outlets that we weren't able to blank, so joined the XUD lower hose from the block to the lower HDI hose.
This was what 3.5yrs ago so I'm going by memory..
ahh fair enough.
so you need a hdi pipe to cut in half it seems cheezy
