Mocal Cooler
Looking for an oil cooler to replace the standard rad fed cooler...
Thermostatic sandwich plate and a small 10 or 13 row would be good.
[Image: New%20GTi6%20Filmstrip%20sig2_zpsu8ocrldg.jpg]
Just fyi, You need to keep the heat exchanger in place even if you do use a mocal oil cooler with stat' plate Smile
you don't have to keep it, seen them fitted both with and without.
I think my exchanger is allowing oil into the water hence replacing.
I've got a 16 row Mocal kit with thermostatic takeoff if that's of any interest?
how much?
(22-06-2015, 08:17 AM)MCH Wrote: you don't have to keep it, seen them fitted both with and without.
You don't have to no bud, but its pretty important to do so.
Remember its not really a oil cooler as such, rather a heat exchanger.
Replace it if needed buddy, find them very cheap Smile
Where?
I had a look but always a bit apprehensive over pattern stuff as had various items fail on me where as when I've spent the extra or waited for genuine its never failed.
£200 odd for a genuine one is a tad pricey
http://www.306gti6.com/forum/showthread.php?id=163789
Non thermostatic sandwich plate but the rest of its pretty close....
Its worth keeping the original heat exchanger. See, it won't cool the oil that much but what it will do is help warm it from cold quicker!
^^^This.
Don't take off the heat exchanger. You gain nothing by doing so and will have to wait longer for the oil to warm up.
See the sheer power and might of the lesser known burrowing owl
Where?
Il do you a second hand one £35 delivered for the oil modine Wink
GTI6 Info
  Wanted: MOCAL oil cooler thermostatic plate +hoses Piggy 7 4,865 09-06-2015, 12:09 PM
Last Post: Stef205
  Wanted: Mocal thermostatic sandwich plate cully 0 1,560 18-06-2014, 10:12 PM
Last Post: cully
