Threads: 183
20
Given 8 thank(s) in 8 post(s)
Try replacing the thermostat, is I hammer mine it will go above 90c but the fan kicks in about 98c iirc and cools it down.
Threads: 6
Car Model/Spec: 1995 405 GLX DT
changed the stat yesterday, forgot to put that
Threads: 11
maybe worth changing the water pump? whilst your at it do the cambelt and adjuster if they have not been done recently.
Threads: 6
it was fine when i drove it home when i first got it then just started to do it all of a sudden, belt has been changed recently too
Threads: 11
has the water pump been changed i see you say the belt has some times the impellar on the aterpump goes.
Threads: 34
8
Given 7 thank(s) in 7 post(s)
What state is the rad in?
Threads: 6
ill check the paperwork tomorrow & its a newish rad its in good condition id say
Threads: 8
Car Model/Spec: xtdt 306
Country:
Are the radiator fans working properly? I didn't have any on my car for a while and it would behave in a similar way.
