Threads: 581
195
Yes but what I'm saying is when they are working properly, they return barely any fuel so if it is returning a lot of fuel, the fault is not with the fpr and is with the supply somewhere.
And then of course you need the air to match that fuel and where's that going to come from unless there is a leak (would be a big coincidence) or the icv is open but if that's the case, why would the idle fluctuate so much?
Not saying its not but I don't think it will be!
Threads: 581
195
I'm sure you said you already tried that? Well at least it's a cheap and easy fix!
Threads: 386
87
Niall it turns out it might not have been that......seeing as it now runs fine without the sensor at all lol. :?
Threads: 581
195
Toms306 Wrote:Niall it turns out it might not have been that......seeing as it now runs fine without the sensor at all lol. :?
That's because if it goes short or open circuit it goes to a default value of -40 meaning it will just run well rich. If it give bad readings, it could potentially do anything!
Threads: 476
81
Car Model/Spec: 306 Rallye
ok i drove with the temp sensor out and it made no difference after all. However disconnecting the MAP gave my fuel ecnomy back and there was no bouncing. it was much better but there was still surge of power where there didnt use to be. I presume this is due to having no MAP?
Threads: 476
81
grrr the icv is sucking in so much air through the breather filter so tbh its probably just everything that is f*cked! D:
Threads: 386
87
Get a new car Sam.....want a golf?
Seriously though, did you try a new map?
Threads: 476
81
havent been to go and find one yet. Ill either go later today or tomorrow!
