hi and wanted ?
hi and wanted ?
Hi guys I currently have a 306td I've had 10 years been good as gold I also have a dispatch 1.9d that I've just pulled then engine from and have a citroen xantia td engine to fit problem is I have less then 10 days todo it and the xantia has a ecu for the bosch pump now I'm guessing it's going to be a ball ache to wire in the ecu so I'm after a pump n injectors asap if any one knows of any please help ?? andy
Not hard to wire at all just use standard loom and ecu swap senors etc to match loom and live power for pump
Job done
Mines a non ecu run engine so didn't want to faff about tbh as would need to modify both looms to make 1 to work. ? tjanks for reply tho
Opps sorry read quickly see what you mean now
