Oil change
I'm trying to do an oil change on my 1.8 xs and can't really get to the filter, and was wondering if anyone could give me some tips to be able to get it off? (Other than jamming a screwdriver through it, which I really don't want to have to do)
Strap or chain wrench should do. Don't stick a screw driver through it.
I don't really have a lot of room to get to it but i'll try it Smile could I somehow move the radiator a bit without disconnecting it?
Nope, you just have to struggle and end up with arms covered in oil and shit, we've all been there... lol
Haha alright then thanks
How much oil does the engine take? I can't find it in the 306 handbook :/
It is in there somewhere lol. I think it's 4.2 litres on the 1.8. Put it in slowly and keep checking the dipstick is your best bet. It also says in the Haynes if you have one of those.
I have this oil filer removal tool:
http://www.halfords.com/motoring-travel/...moval-band
It is great. My friend bought one on my recommendation and also loves it. You can tighten it up around the filter even when there's virtually no access and you tighten it on the knob at the end, and it is very easy to reach up onto a gti6 filter from underneath with so I imagine it'd be the same on the 1.8.
62k Diablo Phase 1 Gti-6:
Project Thread
That's also what I use for these Retro...kinda what I meant by strap wench but looks like that's something different again lol. Really is the best tool for the 1.8/GTi6 that I've used.
Yeah they aren't the easiest things to get to especially if people don't oil the seal on the filter first so it sticks to the block. I got mine off using oil filter grips.
I don't like the band or chain type tools as the handle needs to be perpendicular to the filter which can be a pain. Halfords make a tool that looks like a large set of pliers or grips that holds the filter very well and works at any angle befo the better choice AFAIC
(31-05-2015, 12:14 PM)Dum-Dum Wrote: I don't like the band or chain type tools as the handle needs to be perpendicular to the filter which can be a pain. Halfords make a tool that looks like a large set of pliers or grips that holds the filter very well and works at any angle befo the better choice AFAIC
Thats the same as the ones I've got and they are spot on. If the filter is on stupidly tight, they can slip a bit but the teeth eventually grip and get it off.
I used a really old looking strap type filter grip like this one
[Image: 22843bdb4eacc561b21568deb0ac8554.jpg]
The one I use doesn't slip, if it does it just needs to be tightened up more.
Personal preference seems to play a big part in which tool people prefer.
Project Thread
