DT and NAD head gasket the same??
Well buyin a head gasket for my dturbo on eurocarparts and it doesnt distinguish between 1.9 nad and 1.9 turbo. So was just wondering is all head gaskets the same through the xud range?
                                                      HDI D'Turbo Daily Driver ---- XUD D'Turbo Project
see link in my sig.
On my phone cant translate service box. Any1 know will this headgasket do my job. Its a d8a phase 1 xud9te
http://www.eurocarparts.com/mobile/ecp/c...e63&000173
Anyone know?
It will yep! Could go for 5 notch though to drop the C/R.
Cheers lad. Will see can i get a 5 notch.
Why would you want to lower the compression unless your going for mega high boost?
You'll only be replacing the lost pressure with boost anyway
Cherry red 205 XUD VNT - Project thread here http://306oc.co.uk/forum/showthread.php?tid=25522
Im running about 26 psi anyway so bringin compression down a small bit would probly do no harm. Id say it makes f*ck all difference anyway.
  Possible head gasket issues? forbeslongden 3 4,984 16-01-2020, 09:39 PM
Last Post: Mighty306
  Head gasket (again!) Pughawk 1 3,391 08-11-2019, 08:59 AM
  Head gasket and Engine rebuilds. weka 2 4,778 15-07-2019, 08:46 AM
Last Post: weka
