Threads: 371
29
Car Model/Spec: ford fiesta
What do you need to know im pressing one in for Sam today. If you can make one. I'll give it a go as well.
Threads: 4
Car Model/Spec: diablo hdi
Given 2 thank(s) in 2 post(s)
Country:
what material are you planning on using?
Threads: 476
81
Car Model/Spec: 306 Rallye
Given 103 thank(s) in 101 post(s)
Ask bash and see if he can measure mine before its pressed.
Threads: 371
29
Outside diameter 70mm
Width of bush 40mm
Width of centre as its longer 50mm.
10mm bolt hole.
Threads: 476
81
bash are you going to share your idea?
Threads: 117
119
Given 105 thank(s) in 105 post(s)
22-05-2015, 02:28 PM
(This post was last modified: 22-05-2015, 02:29 PM by Poodle.)
Stupid place to ask if he isn't, he's in a bind now lol.
Threads: 371
29
(22-05-2015, 01:25 PM)Eeyore Wrote: bash are you going to share your idea?
Lol. People are more than welcome to know. Im planning on getting some ally inserts made up cheap that will press into lower mount allowing it to take a different solid bush. Say off a leaf spring. That way the parts are dead cheap and easily replaceable. Im still working on it though and will test it on my motor first. I have a few bushs un mind. Its a matter of finding the correct one
Threads: 136
11
On a diesel? Do you wish to have a dashboard/car/teeth/ear wax left?
Threads: 6
1
Car Model/Spec: Yes, lots!
Be very careful not to go to hard, I made up a nylon bush for my rally car and it quite quickly snapped the lower fork. To be fair the car gets abused and has a reasonably harsh paddle clutch but I know a lot of the derv guys on here use paddles. You need a bit of compliance, oh and a solid one would piss you off at low revs, I'd never do it on a road car/daily!
Threads: 136
11
I used a group A fork mount for 2 days before I took it out and that was on a petrol
Threads: 371
29
Im just after testing one to be fair. If I can make the inserts work and at a fraction of the cost I may do a group buy if people are interested but this is all a long way off at this time. I have other stuff im concentrating on at this time. Personally on my daily ill run an oem lower mount rotated 90 degrees.
Threads: 30
5
Car Model/Spec: 306 HDi Dturbo 5dr
Country:
Do they last longer at 90 degrees then?
![[Image: 9fa12c59-0c3d-4413-968d-6a7840ff068f.jpg]](http://i693.photobucket.com/albums/vv295/highwayman306/9fa12c59-0c3d-4413-968d-6a7840ff068f.jpg)
Threads: 371
29
No but it makes them more solid so to speak.
