Threads: 4
Car Model/Spec: 306 XRD
Hey Hey
My 1.8 diesel engine is becoming boring to me with only 60hp.
I was thinking to swap to 1.9 td 92hp.
Can you guys tell me if it is plug and play ?
A friend of mine said it is but i wanna know from other people
Greetings from Portugal
Threads: 371
29
Car Model/Spec: ford fiesta
Pretty much plug and play. Use as much of the 1.9 as possible. Best get a donor car
Threads: 4
(20-05-2015, 05:49 PM)bashbarnard Wrote: Pretty much plug and play. Use as much of the 1.9 as possible. Best get a donor car
ty for the quick response man
i will buy the engine on the
waste (crashed cars)
Threads: 371
29
Best thing. Everything is pretty much plug and play. Just use the wiring harness off the 205. If you have pas you are best to ditch it off as it runs on the back on the 205 from memory and front on 306. 205 drive shafts will fit. You can use the 205 box if you want. If you use a 1.9 box though it has longer ratios. I think that's all I know.
Threads: 4
(20-05-2015, 06:12 PM)bashbarnard Wrote: Best thing. Everything is pretty much plug and play. Just use the wiring harness off the 205. If you have pas you are best to ditch it off as it runs on the back on the 205 from memory and front on 306. 205 drive shafts will fit. You can use the 205 box if you want. If you use a 1.9 box though it has longer ratios. I think that's all I know.
Hummm, let's see if i get it
What i need:
- Wiring harness off the 205
- drive shafts from 205
- gearbox from 205
My friend told me too that 1.8 gearbox is the same as the 1.9 (piece of cr*p).
didnt understand that part,
Threads: 371
29
Yes yes and no. You can use the 1.8 gearbox. But it will rev really high on cruising. The 306 box is better. If you really want to drop cruising revs a 306 hdi box will fit.
Threads: 92
5
Car Model/Spec: Subaru 20.d, GTi 6, 205 xs
Iv got 2 gearboxes already converted if you need them, use the 1.8 water system and swap all the sensors for the 205 ones then the harness will be plug and play check my project thread for more info
Current cars
Subaru Impreza 2.0d - Daily
Threads: 4
(20-05-2015, 07:24 PM)td_dan Wrote: Iv got 2 gearboxes already converted if you need them, use the 1.8 water system and swap all the sensors for the 205 ones then the harness will be plug and play check my project thread for more info
But i'm a student and i do not wanna spend to much money on 1 time.
I prefer to do the basics, then going to upgrade
Threads: 92
5
As i said read my thread, but really just buy a smashed 306 with working engine and tiu will have everything needed
Current cars
