Unplugged a fuse and now lights keep flickering
Thumbs Down
Hey guys,
So I am leaving my car parked for a while and wanted to find the main fuse so the car couldnt be started etc. I tried to pull a few fuses and couldnt find the right one. I by accident pulled out a 20AMP fuse on the top right part of the fuse box.
I tried to find fuse box layouts but not sure if I have a Phase 1 or 2 to be honest.
I plugged the fuse back in, but then my headlights started to flicker. I got panicked and decided to unplug the brown relay under the steering column. It is a big 5 pin relay and heard it flickering every time the lights went on and off.
Can someone please tell me what I did and how to fix it? I cant clear the ECU yet, need to take it to a workshop for that sadly Sad And this had to happen after I misplaced my key as well! What a day! FFS
Thanks a mill guys, appreciate your help
Ex cars: '86 Opel Monza 1.6 GLS Puke & '97 Opel Astra 180ie 16v - oil spill & '07 VW Polo 1.9TDI (stolen) - Awesome car!
"I went to the woods because I wanted to live deliberately. I wanted to live deep and suck out all the marrow of life." - Henry David Thoreau
Were they flashing on and off? Sounds like alarm to me on a ph1. You need to put that fuse back in, relay back in and start the car and it will stop Smile
Yeah flashing on and off, no sound or anything though.
I thought it may be the alarm, but I started it even. Let me take her for a quick spin and see then
Edit: Here is the fuse that I had to unplug to stop it
http://www.ebay.co.uk/itm/Citroen-5-Pin-...4ae87cd1ba
If not, another thing to try is take the battery off, fuse and relay back in, key to stage one and battery back on
(14-05-2015, 04:32 PM)Niall Wrote: If not, another thing to try is take the battery off, fuse and relay back in, key to stage one and battery back on
Thank you kind sir, I shall try that next. I tried to take the battery off and plug it back in, but obviously a capacitor in the circuit kept charge.
So I just pulled the brown 25A relay out for the time being Smile
Took her for a drive, no dice Sad Still happens, left the relay out and thats that.
Ok so I left my battery off for 2 weeks while I visited SA and came back, put the brown relay back in, and the lights still flicker.
Is it possible I need to plug in an OBD port and clear errors/notifications?
I am not sure, at this stage I just left that relay out since its the alarm one as far as I can tell.
Any other advice or things I can try?
Thanks guys
Ok resolved this guys, just had to follow Nialls instructions properly and everything was ok Smile
Good to hear lol
Rainbow flickering interor lights heater fast slow Welshy_Pete 13 7,921 21-12-2016, 11:23 AM
Last Post: Welshy_Pete
  Instrument lights, dash lights not working boggs 3 4,689 26-01-2016, 09:34 PM
Last Post: DeeTurbo
  Odometer lights and clock lights inop bashbarnard 3 4,059 23-07-2014, 08:43 PM
Last Post: DarkInferno
