citroen zx Hub nuts and dust caps
Another one for the zx and maybe 306 lot
I'm replacing the front left bearing (comes with nut) and my rear brake cables are due a change,
Does the Zx use reusable hub nuts or are they the type you replace
When I did the reasr bearings on my old 1.4 ZX with drums the nut was reuseable afterwards, so was the cap after a bit of tapping back in to shape.
No idea if it should be reusable ot not but I still see it locally and it's not been off again (it took a few chisel taps as I got the cap off and I lined the marks back up, they havent moved)
Cheers mate some are reusable type so it seems the zx has that type Smile
The back ones are one use but...... If you swap them to the other side of the car it will give you a fresh piece of nut to stake into place, the fronts are reusable Smile
(10-05-2015, 11:10 PM)Mattcheese31 Wrote: The back ones are one use but...... If you swap them to the other side of the car it will give you a fresh piece of nut to stake into place, the fronts are reusable Smile
Excellent cheers matt so il just swap the rears over and it doesn't matter on the front Big Grin
That's the one fella yes, Smile
Great cheers Smile
That's so pikey!
I love it! [emoji23]
Haha yes it's pikey, hub nuts are only a few quid each but it's good to know if u cant get hold of any and you need to work on the drums Smile
If it works it works :p
That's so pikey!
Name of a new hit TV show? Haha
  Rear caliper piston dust boot Dangti6 3 3,045 02-05-2016, 03:15 PM
Last Post: Stef205
  Front Caliper Dust Seal Protector Alan_M 2 2,557 27-02-2016, 09:27 AM
Last Post: Alan_M
