engine water intake ?
Disaster last week long story short hit a flood in the 306 and suspect boddies sucked in water. Done compression test which turned out
190 180 185 180
Does that sound about rite?
Was gonna pull the sump off see if a could see a bent rod or not. I've got a spare phase1 engine in a shell if shit hits the fan
looks pretty even across the cylinders, spark plugs out and spin it over on the starter, clear any water (if any) out, clean the sparks and give it a go
did it cut out in the flood?
Project: Formula Peugeot
Compression seems fine. If it locked you would've known about it. If you've bent a rod. Once running you will know about it. Makes a horrid noise in me experience.
So found this today before I ripped it all apart pure coincidence when I hit the water I dunno. Al get a new coil an see what happenes
  Engine Water with alot of pressure Pingaz 4 2,905 14-05-2016, 01:45 PM
Last Post: Pingaz
