ph1 heater fan system
so got the ph1 heater controls and system in
I had it all working fine. Then it stopped. - the fan that is
Its very simple supply, 12v ignition, earth and a 12v lighting supply.
All those are still good.
The heater controls seem fine, very basic internally, just tracks, all fine, no burnouts etc
The fan runs if given 12v/earth.
The fan has 12v when ignition on, assuming thus its controlled on the earth side. (I'm no electrical expert!)
The resistor pack is brand new.
Any suggestions?
Relay working ok? Mine overheats a lot.
P1 XSi track car
2.4 LWB T4
well its getting 12v constant. and it never works now, not when left overnight or during a journey etc
Are you testing it with a test light or a multimeter. If its a multimeter you could easily get 12v and have resistance. No amps getting there. Check resistance of feed 12v wire. Or be a pikey like me and stick a test light on it. If it lights up but dim you know you have resistance. Lol
bridge out the resistor put money on the thermal fuse has gone in it
GTI6 Info
(04-05-2015, 07:20 AM)cully Wrote: bridge out the resistor put money on the thermal fuse has gone in it
you know which pins cully??
not from work i dont ,
one pin will be the supply ground, then the others will be different resistor values, which are selected via the speed switch .
this resistor block is normaly placed/fitted in the airflow tubbing, as it gets hot and needs cooling, when it gets too hot it breaks the thermal fuse, stopping the blower motor.
GTI6 Info
Just a quick thought as well. Mine blew two resistors. Got so pissed off I bought a new fan and resistor from scrap yard.. Been fine since. I think the fan was on way out and drawing to much current.
(04-05-2015, 07:49 AM)cully Wrote: not from work i dont ,
yeah man I know where it is, replaced it 10days ago with a brand new one.
I'll get the tester out.
(04-05-2015, 11:23 AM)bashbarnard Wrote: Just a quick thought as well. Mine blew two resistors. Got so pissed off I bought a new fan and resistor from scrap yard.. Been fine since. I think the fan was on way out and drawing to much current.
just been thinking same thing
guna whip motor out and strip/clean
  Low pressure - heater system Iaitoo 7 4,438 22-11-2015, 11:17 AM
Last Post: Iaitoo
