266mm brakes under volcane wheels
So looking at a brake upgrade for the zx, as it'll need discs and pads before mot. I don't want to get rid if the volcanes for 2 reasons one being I want to keep it original looking out side, and 2 I've just fitted 4 new Michelns not long ago.
So I know it's extremely tight under the volcane wheel but is it possible to fit the 266 brakes under there and if so what needs doing to get them to fit? Will I need spacers?
Thanks in advance
They're a 15 aren't they? Should piss 266's I would have thought Smile
I thought Volcanes were 14s?
It'll be tight if they do fit, 14" swallows only just fit over 266s...all it takes is the butterfly spring to pop out of the caliper (~2mm) and you end up with a massive score mark around the rim lol.
Caliper needs trimming a bit
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Volcanes are 14s so probably will need to take a bit of the calliper
Yer there 14's wish they was 15's I'd be having gti brakes then.
(29-04-2015, 09:52 AM)Anton Wrote: Caliper needs trimming a bit
Do you know how much of the Caliper needs trimming off? Or is it just a trial and error job
the 15" 16v wheels wont take anything bigger than 266.
  Smallest wheels to fit dturbo brakes ginge191 12 7,770 26-09-2016, 05:38 AM
Last Post: ginge191
  306 HDi Brakes (266mm) replacement parts hpi_matrix 14 7,968 02-10-2015, 05:36 PM
Last Post: MY95
  Best 266mm Calipers/Brakes MY95 11 4,934 19-09-2015, 08:40 AM
Last Post: MY95
