How low is my rear beam?
Hi Guys,
New beam is being built up and I need to let Stef know how low I want to it to be. I want it to be the same as it was previously...
[Image: IMG_20140721_210615_zpsfqpxulha.jpg]
Front is down 60mm and I reckon the back is lower than the front so im thinking rear is 60mm too?
Cheers
Too low, about 80mm atleast?
That looks like Kris' 60mm. My black 3dr that Cheez has now is a similar height & was done 60mm by Kris.
(16-04-2015, 07:44 PM)JJ0063 Wrote: That looks like Kris' 60mm. My black 3dr that Cheez has now is a similar height & was done 60mm by Kris.
was lowered by the previous owner who worked at peugeot.
Thats a min 80mm.
But for track work you wont want it that low imho
Plus if its for the track car...surely it will weigh different, thus be a diff height anyhow
As i said to you earlier sam if you have time, jack it up on the rear and remove one rear shock and measure between the top and bottom shock holes.
If its -60mm lowered your looking for 305mm+/- and if its -80mm it will be around 300+/-
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
Another post for 80mm and obligatory too low comment.
I'd say 75-80
Remember people they's no weight on it like there would be usually with seats,carpets etc.
[Image: Cn91r40h.jpg]
80mm imo!
Too low though. Tongue
  Rear beam ...the good and the bad Mighty306 35 31,305 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,421 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 15,863 18-03-2019, 03:40 PM
Last Post: MOK
