10-04-2015, 07:40 PM
Is it just me or am I missing a pipe from here? When engine is hot and stood it sometimes releases a little pressure along with coolant.... [attachment=22600]
Am I missing a pipe?
10-04-2015, 07:42 PM
I suppose you are missing the pipe, but on mine, that pipe is literally only about 4" long at most! So it's not like you're missing much!
10-04-2015, 07:57 PM
Rite that's fine then.... I will get a bit of general pipe just to route it so it doesn't leak everywhere lol. Cheers mate
10-04-2015, 08:29 PM
It's just the overflow, if its chucking it out regularly there may be an issue.
10-04-2015, 10:33 PM
I have only recently noticed the dried coolant around the tank as you can see in the picture. Watching it idle after a long drive it spat little bits and bobs out just few drips really as it got to around 80 degrees on the gauge....temp usually is around 72/75 ish on the gauge.
10-04-2015, 11:04 PM
Weathers getting hotter, it's normal.
11-04-2015, 05:47 AM
Not if you don't regularly overfill your header tank it's not, it's probably just the cap getting a bit old. Should sit around 80, probably got a stuck thermostat there.
Really! I have always been told hdis sit lower 70s normally! When it went to 80 sat on the drive I just put that down to engine warming itself before fans kicked in.
I struggled to find a max marker on the coolant tank too so I just filled it the top of the bit of plastic inside the tank sat in the middle
11-04-2015, 09:41 AM
(11-04-2015, 09:13 AM)td163 Wrote: Really! I have always been told hdis sit lower 70s normally! When it went to 80 sat on the drive I just put that down to engine warming itself before fans kicked in. It says 'max' under the red arrow in your pic ![]() Its halfway up where the lip is
11-04-2015, 12:33 PM
I mean cause it's not see through its hard to tell looking inside the tank when it hits the seam lol
11-04-2015, 03:12 PM
Yeah that seems to be a popular misconception...
That plastic marker is the level indicator for the exact reason you've stated, so that should be fine.
11-04-2015, 08:51 PM
Cheers mate! I'll start buy sorting the thermo & a new coolant cap see how we go.
| missing relay | pug306driver | 10 | 4,889 |
25-01-2016, 12:58 PM Last Post: DeeTurbo |
| Bit of a stange one missing and back firing | titch | 24 | 11,464 |
29-08-2014, 04:27 PM Last Post: titch |
